Old 09-08-2005, 07:18 PM   #5 (permalink)
Hoser
Info on Leer Tonneau
Hi heat,
I checked out several hard tonneau shell covers, Raider makes one but does not have the raised lines that give the Leer a sporty look. Leer has two models, I went with the Leer 700 model, a little more exspensive. This hard shell has a few good things going for it, heaviest of the hard shells, comes black carpet lined, key lock at the end not on top and has a sportier look than most. It fastens to the Titan's bed rail system, multiple adjustments makes for a very tight fit. I did have to adjust an extra rubber seal at the two front corners to prevent any water leakage up front. Sides seal tight with no water leaks, I'm very pleased with the fit and Leer quality. Ordered it from Leer in California in primed grey, cost 1000 canadian, had a local body shop paint it for 250.
Hoser is offline   Reply With Quote
