The following is an alphabetical listing of the various exhaust systems available for the Nissan Titan. Some are complete cat-back systems, others are custom one-offs. If you would like to have you system added to the list, simply PM me and it will be added.
To help makes things easier (on me at least), please use the following bbcode format when submitting your clips. Simply copy the code below and change the appropriate information. Then paste the changed code into your post.
[indent]►Exhaust Brand Name / Short Description
♫[url="http://www.your_link_to_clip.com/file"]Sound Clip #1 (description)[/url]
Owner: [url="http://www.titantalk.com/forums/members/YOUR_USERNAME.html"]YOUR_USERNAME[/url]
[/indent]
If you don't have a place to upload your clip, try http://www.putfile.com/
Banks►Banks Cat Back System
♫Sound Clip #1 (zip file)
Owner: 37L1
http://s93.photobucket.com/albums/l8...ators_0001.flv
Owner: RB's Titan
♫Video Clip #1 (burn out)
♫Video Clip #2 (exhaust revs)
♫Video Clip #3 (inside cabin)
♫Video Clip #4 (now with Stillen Headers)
Owner: RB's Titan
♫Video Clip #1
♫Video Clip #1 (same clip, different file location)
Owner: Daves_Titan
♫Video Clip #1
Owner: GreenT
B&B►B&B Cat Back System
♫Video Clip #1 (mov file)
Owner: QShip
Bassani
Clips Needed
Borla
►Borla Turbo XL Muffler installed into a Gibson Extreme SS Dual system with Borla tips.
♫Sound Clip #1 (drive by)
Owner: Finnattic
►XS Turbo Muffler 3" in, dual 2.5" out
♫Sound Clip #1
Owner: Voodoo
►XS Turbo Muffler installed using Flowmaster American Thunder cat-back pipes.
Owner: RockyMtnTitan
►XL Turbo with stock pipes
♫Video Clip#1 (startup and revs)
Owner: SARswmr
Dynomax►Dynomax / Muffler only, stock pipes
♫Sound Clip #1 (low revs)
Owner: tallytitan
►Dynomax / muffler with stock pipes
♫Sound Clip #2 (higher revs)
Owner: tallytitan
Flowmaster
►American Thunder Cat-back system (70 Series), Single In, Dual Out.
♫Audio Clip #1, 2, 3 (zip file, mp3 format)
♫Video Clip #1, 2 (zip file, wmv format)
Owner: caltitan
♫Video Clip #1 (mpg revs in neutral)
Owner: m95roadster
►40 Series swapped in to OEM exhaust system
♫Video Clip #1 (startup and revs)
Owner: jeffs05SE
►50 Series SUV Performance 3" In/Out, Side exit Magnaflow 3" In/4" Out Tip
♫Sound Clip #1 (.zip file)
Owner: StriKing_Cobra
►70 Series Big Block II dual 2.5" In/Out, SS X-pipe, 3.5" rolled tips straight back.
♫Sound Clip #1 (inside accel to 40)
♫Sound Clip #2 (inside hard accel 10-60, accel to 80)
♫Sound Clip #3 (outside revs)
More Information
Owner: Sammy Sandbag
Gibson
►Gibson Stainless Split Rear
♫Video Clip #1
Owner: charliethetuna
JBA►JBA
♫Sound Clip #1 (start up and drive by)
Owner: vk56inftw
MagnaFlow►magnaflow custom/single 2.5" in dual 2.25" out
♫http://media.putfile.com/titan-exhaust
Owner: rsw007
►Custom 2.5" true dual, no resonator, Magnaflow XL mufflers
♫Sound Clip #1 (MP4, start up and short revs)
Owner: kartman
Nissan OEM Exhaust►Factory Exhaust
♫Video Clip #1
♫Video Clip #1
Owner: Daves_Titan
PowerFlowUSA Headers►PowerFlowUSA full length headers, Custom true dual 3", MagnaFlow X-pipe, dual MagnaFlow 5x8 ovals, 3" UltraFit Turbolator Tips.
♫Clip #1 (Dyno Run)
♫Clip #2 (run to 100mph)
♫Clip #3 (interior hwy check)
♫Clip #4 (revs)
Owner: Thrust_Titan
Ractive►Custom 2.5" true dual, x-pipe, side exit
♫Video Clip #1 (MOV, revs)
More Information
Owner: gr8titan
Stillen►Stillen Single Side Exit
♫Vid Clip#1 (revs)
♫Vid Clip #2 (startup)
Volant
Clips Needed
Zoomers►Zoomers Cat-Back System
♫Video Clip #1 (WMV 10mb)
Owner: Yomama
♫Video Clip #1
♫Video Clip #2
Owner: Howie Kaluha
[/indent]
