Old 09-22-2005, 09:01 PM   #2 (permalink)
grunge311
grunge311's Avatar
First, do you know if your doing XE, SE or LE? The rockford package would change things slightly.
If you know your going to do carPC, and you know your going to like it, and you know your going to go all out and do it right, then do NOT get the nav. Waste of money.
assuming you get the rockford, and all you wanted was to add the carpc, then I would get the nav bezel, a 7" touch screen for it, and run the audio out from the pc into the aux jack in the rockford, that way you would still have a front load cd player. DVDs however you would have to be creative in mounting them.
That would be my "minimum" way to do it.
Next step would be to eliminate the rockford (or don't get rockford to begin with) replace with a good quality audio deck, then get a DVD rom drive that is single DIN mountable (USB) that way you would have front loading DVDs (for movies)
grunge311 is offline   Reply With Quote
