Old 09-23-2005, 09:10 PM   #120 (permalink)
RockyMtnTitan
RockyMtnTitan's Avatar
Strapped her up to the dyno again today. This was my third trip since buying the truck almost a year ago. Thought you all might like to see the progression from almost stock (KN w/ airbox mod) to where I'm at now.
Note that on the last scan, I did a before/after ecu reset so you can see that there is some gains from doing this. I had just done a reset after installing the AFE a few days ago, and have been doing a lot of data logging with my foot into the pedal. So, the little bit of learning the ecu had done, prior to the reset I did tonight, was pretty aggressive...thus a smaller gain...if that makes any sense! The reset gave me my best dyno numbers so far, and this was on my 4th run tonight when the motor was the very heat soaked.
I also logged a bunch of data with my scan tool for all of the runs to send to Ron at ProAuto for the "black box" he'll be flashing for me ( I hope!).
I'm pretty happy with my results at this point, although I can't seem to get my torque above 333 no matter what I do.
Of note--All dynos were performed at the same shop/dyno/operator.
Here's the progression:
*Baseline* Dyno session #1:
Mods: K&N panel filter, airbox mod
HP: 253
TQ: 304
Dyno session #2:
AeroTurbine custom exhaust
HP: 260 (gain of 7)
TQ: 331 (gain of 27)
Dyno session #3:
Mods: AFE Stage II Intake, Airaid TBS, TB Coolant Bypass,
FM cat-back w/ Borla XS Muff, Rear cats deleted
HP: 281 (gain of 21)
TQ: 331 (no gain)
*After ecu reset:
HP: 285 (gain of 4)
TQ: 333 (gain of 2)
Total gains since initial baseline dyno:
HP: 32
TQ: 29
Not bad for a few bolt-ons!
Thanks!
consolidation-mods-dynos-track-times-dyno-results-kn-airbox-mod-aeroturbine-exhaust-12-2-04.jpg AeroTurbine Exhaust - 12-2-04.jpg
ID:	16637  consolidation-mods-dynos-track-times-dyno-afe-intake-tbs-fm-borla-exh-rear-cat-delete-tb-coolant-bp-9-23-05.jpg  consolidation-mods-dynos-track-times-dyno-bef-aft-ecu-reset-9-23-05.jpg
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
