Seats installed and great
The seats with a memory system do not just plug in and work. I had to pull all the computer system under the seat and trace all the wireing. But I did get them working.
One each motor only takes two wires and the side that has the three extra wires are the wires to the memory system. Also the wires comming out of the switch for the seat only has 9 wires and there are five motors so you have to share a ground or drop of one of the motors ( The back seat ) lift is the least used. If you share the ground you have to be some what tricky with the switch to get it to trade between the lifts.
Anyway it was a long project but it worked.
Robert
