Had the first trip to the 1/8 mile strip tonight.
Wichita Falls, TX 1000ft ASL
1st run temp 90ish degrees 2nd run 30 minutes later
Reaction 1.3573 0.8315
60 Ft 2.2655 2.3174
330Ft 6.5522 6.6277
1/8 ET 9.9746 10.0700
1/8MPH 70.33 70.01
1st run was a mash and go, no stall.
2nd run was with the ECU reset and I stalled to around 2000RPM
I had 1/2 tank of gas (87) spare was on and 2 car seats installed. I didn't touch the tire pressure either. 1st run I blew away a mid 80 Cheby truck that ran a 12.32. 2nd run I ran a 2001 Furd F150 that ran a 10.98.
I detailed the truck before I left. Since I wanted to make a good impression, because you don't see many Titans up here in north Texas. I really wanted a hemy to show up but no luck.
Next time I'll remove the spare, change tire pressure to 50 (the head advises), lower gas to around 1/4 tank and remove the car seats. Also, if I go on the Atkins diet. j/k
04 is GONE.. White CC, SE, 4x2, Big Tow, Bed extender, Factory Bedliner, Splashguards, Pinstripping
Banks Monster, K&N FIPK, Extang Tuff Tonno, AVS Bug Deflector, AVS In-Channel Vent Visors, AVS Rear Window Sun Reflector, AMSOIL 5W-30, Differential-Royal Purple 75W90
Best 1/8 run 9.7239 @ 71.85 mph
1/4 run calculated conversion 15.13 e.t.
06 Black beauty, KC, SE, 4x4, Texas Edition
Gone!!!!!!!!!!!!!!!!!!!!!!! 15,000 miles
08 White CC, SE, 4x2, Factory tow hitch, Splashguards, 20% Tint, AVS Bug Deflector, Extang Tuff Tonno, AMSOIL 5W-30, 8000 Miles
Pioneer DEH-P7800MP, Rockford Fosgate Punch P5002, 2 10" Rockford Fosgate Punch Stage 2 DVC, Custom RF box built by Tech12volt.
