Old 09-29-2005, 09:32 AM   #4 (permalink)
bestatchess
Originally Posted by keane
Your CD can continue to run if you are set up to listen to the back headphones. Check to see if the little headphone symbol is showing on your display. If it is, turn it off by pushing the headphone button. This should fix the problem. Mine has done this in the past.
good luck
Ahhh, good point!
