Old 10-09-2005, 07:02 PM   #6
92TripleBlack
92TripleBlack's Avatar
Originally Posted by heath22
I know that bigger is better and bigger pads = better stopping and all that...but if I put 22" wheels with a 305/45R22 tire which is the same rolling diameter as my stock 18's with 265/70R18 tires then how is that more stress on my rotors and pads when coming to a stop? I wouldn't guess the weight to be more since the tire is smaller and the wheel may weigh more but wouldn't it all kinda wash with the OEM setup? Now the look of a small rotor my be visually out of wack with a big open wheel, but that is just looks. Again, I know what all will come back with, but again, on paper what's the difference? Maybe I'm just tired and need to clear my mind, but I was just thinking about this while I was online looking at wheels for my Titan.
Thanks,
Not much.
Bottomline is the new redesigned rotors are more than enough for braking. Think of it this way, these brakes are large enough for towing 9k, they can handle your rims. You can go bigger for looks, but it isn't necessary. Just remember not one maker of drilled rotors offers a warranty as they crack. If you want to get bigger rotors, get plain or slotted. Slotted will vent a little better, and also cause more dust and pad wear. Coatings are gone after 100 miles on the braking surface but usually remain elsewhere.
If you want other rotors than the new stock ones, I'd get these with a set of ceramic pads.
http://www.tirerack.com/brakes/brake...tor&perfCode=S
http://www.tirerack.com/brakes/brake...ads&perfCode=P
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
