Originally Posted by dawgs77
Are you really hard on brakes?? Just asking.......rotors get warped.....maybe you have another problem....maybe the rear isn't holding as much as it should.....maybe you have uneven pistion pressure on a caliper.....maybe you drag race to each stop light making the brakes very hot....
Give me any car/truck with what you consider good brakes and I can warp the rotors....
Must be, or must not be breaking in the brakes. I had the first set on the Armada, which weighs more and has large wheels and tires, for almost 9K without warping. They started to squeak so I had them replaced with the new brakes, which are now in stock at dealers. The new brakes work great. I brake hard and drive faster than anyone I know. I also tow. Not sure why he's having so many problems, again unless he is breaking them in incorrectly or not at all.
Here's what makers recommend for breaking-in brakes on the Tirerack site. No difference for brakes from a dealer.
http://www.tirerack.com/brakes/tech/....jsp?techid=85
