Originally Posted by Demondw3
I would go with the 17x8. I have procomp version of the 187's 17x9 +2mm offset and my left wheel rubs at full turn. That's just my opinion or you can do some trimming and it will solve all your problems.
They fit 8.5-10" and prefer a 8.5" rim. Kinda wierd the preferred rim size is the bottom of the range. Usually its middle of the range. They also would be 34.5" in diameter, which is pretty small for an 8" lift. You could fit them with a 3" lift. Most guys with 8" go 37" tires. You could go 37x12.5x17 on a 17"x10" rim.
http://www.tirerack.com/tires/Spec.j...tnum=17R7ATAKO
