Old 10-20-2005, 07:29 AM   #5 (permalink)
SickWhip
SickWhip's Avatar
Originally Posted by buzzkillwill
I believe the weight is 60 lbs. for the airbag to be 'active'. Otherwise, the light will stay on/lit, if less than 60 lbs. is in the seat.
If you're having a problem, as some have had in the past, take it back to the dealer and have them check it. Some were having problems with the connection for the sensor, others had to have the seat replaced.
I took mine in for this reason on tuesday and the reply was.... (tech) "I called Nissan and they said that nothing is wrong with it. Nissan says that its not just a certain weight that turns it off, its mass. If a person of small mass sits in the seat, the airbag will not deploy. If the airbag goes off and someone doesn't have enough mass, they could get hurt." I didn't like this awnser at all and don't know what to do about it. I also told them that the reception owas bad on the new radio that they installed and they said that everything was connected right and the stations I had problems with where too far away. They are about 25-30 miles away (Columbus, GA). What do you guys think I should do?
I want my baby back, baby back, baby back....
