Originally Posted by NissanCowgirl
Do I need to be more concerned with 20" rim number or the 10" wide number for the rims.
Nissan sells Titans with custom 20" rims. Why should these 20s affect the warranty and/or differential.
Remember you are dealin with a girl here. Thanks.
Niether, the offset. This is how deep the center of the rim is in relation to the edges. If you have no offset, the center will be centered halfway from front to back. If as you add or subtract offset, the rim will move closer in or stick more out from the truck. 20" is meaningless. The outer diameter of the tire is all that matters. Also, 10" is pretty much meaningless as you can always have the rim stick out more. I have 305-55-20 tires on mine so they will fit. I needed to use a heat gun to melt the inner fender well slightly to stop rubbing. Took 2 minutes and looks stock. They can do this for you. What you need to worry about is how close in or how far out the tire sticks from the truck. Too far in and you will rub. Too far out and it will look funny and spray rocks/etc. on the side of the truck. Also, you need to make sure the design of the rim doesn't rub on the brake calipers. Like I posted earlier, don't worry about them fitting. They will. You just need to make sure you have the correct offset and that they won't rub the brake calipers. Plenty of people have 20x10 by the way also. Contact the back office and ask them what offset you need for that rim to fit a Titan. If you don't want to have the heat gun treatment, just get 305-50-20 and you will be fine. They will be about 1" shorter, and the truck will be 1/2" lower, that's all.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
