Old 10-25-2005, 04:31 PM   #127 (permalink)
Kronos1965
Kronos1965's Avatar
Track times and losing weight
Originally Posted by HemiETR
Had the first trip to the 1/8 mile strip tonight.
Wichita Falls, TX 1000ft ASL
1st run temp 90ish degrees 2nd run 30 minutes later
Reaction 1.3573 0.8315
60 Ft 2.2655 2.3174
330Ft 6.5522 6.6277
1/8 ET 9.9746 10.0700
1/8MPH 70.33 70.01
1st run was a mash and go, no stall.
2nd run was with the ECU reset and I stalled to around 2000RPM
I had 1/2 tank of gas (87) spare was on and 2 car seats installed. I didn't touch the tire pressure either. 1st run I blew away a mid 80 Cheby truck that ran a 12.32. 2nd run I ran a 2001 Furd F150 that ran a 10.98.
I detailed the truck before I left. Since I wanted to make a good impression, because you don't see many Titans up here in north Texas. I really wanted a hemy to show up but no luck.
Next time I'll remove the spare, change tire pressure to 50 (the head advises), lower gas to around 1/4 tank and remove the car seats. Also, if I go on the Atkins diet. j/k
Don't forget to remove the tailgate and instead of Atkins, eat Twinkies. They're light, full of sugar and you'll be so hopped up, your arse won't touch the seat and therefore it won't count as weight in your truck
Kronos1965 is offline   Reply With Quote
