Old 10-31-2005, 02:56 PM   #29
oktex88
Send a message via AIM to oktex88
Originally Posted by rtapia
The truck isn't supposed to be running when you do this. The ignition should be in the "ON" position. This is when the engine isn't running but you have power to your instrumentation.
I did the following:
Idle Air Volume Learning (Throttle Position Learning)
It is better to count the time accurately with a clock.
Operation Procedures
1. Perform “Accelerator Pedal Released Position Learning”.
2. Perform “Throttle Valve Closed Position Learning”.
3. Start engine and warm it up to normal operating temperature.
4. Turn ignition switch “OFF” and wait at least 10 seconds.
5. Conform that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds.
6. Repeat the following (steps 7a, 7b) procedures quickly five times within 5 seconds.
7a. Fully depress the accelerator pedal (HARD)
7b. Fully release the accelerator pedal.
8. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 20 seconds until the Check Engine Light (CEL) stops blinking and turned ON.
9. Fully release the accelerator pedal within 3 seconds after the CEL is ON.
10. Start engine and let it idle.
11. Wait 20 seconds.
12. Rev up the engine two or three times and make sure the idle speed and ignition timing are within the specifications.
Now look at step 10.. says to start engine and I waited then on step 12 when I reved it the check engine light would flash when I reved it. Then after about 5minutes it didn't do it when I reved.
2004 Nissan Titan - Cash Settlement with Nissan for Water Leak March 2008
oktex88 is offline   Reply With Quote
