Originally Posted by buzzkillwill
Congrats on your new toy!!
I got the Banks a few weeks back, but I've got an issue...
When I'm sitting at a stop light, and my truck is at idle, in gear, I get this vibration from under the truck. It only happens when at idle, and it's only when it's in gear. So my concern was it was the rear end.
So I had my wife sit int he car with it in gear until the vibration started, then I got down beside the truck and pushed on the exhaust, and it stopped. THe next time I pushed, it changed the tone of the vibration, so I'm sure it's NOT the rear end.
But it still doesn't solve my problem...
I've gotten under the truck two times, checked to make sure nothing is rubbing/touching, and it's not-and everything is tight....any ideas anyone...??
I had a saw blade sound and vibration coming from rear hanger. Had it repositioned and now it's quite.....BUT NOW I want to know if you figure this one out yet?
I still have the vibration and the vibration with sound resonace in the cab at the first line of rpm gauge (500). It is also only there in "D" with brake on under idle load not "R" or "N". This is driving me crazy as I have a completely welded system. At first I thought is was exhaust. Then I started thinking the Volant was leaking after the MAF so I re-installed the stock airbox today. Well the vibration is still there however the vibration and sound has decreased some. But the rpm also increased 50-100. So now I'm really going nuts? Is it an air leak, a bad MAF, a quick fix with an ECU idle adjusment at dealer, torq converter? I'm grasping at straws but definately looks like we need help Buzz.
