Old 11-10-2005, 07:54 PM   #13 (permalink)
Vyrus
The bolt is there to hold the rubber grommet. The grommet is what actually holds the box on, and the box "pops" on and off it. You will understand when you go at it tommorrow, just make sure to put your center bolt back. Then pull upwards and the box will pop off the grommets. Then you can remove the bolts if you wish.
-Cyrus
Vyrus is offline   Reply With Quote
