Old 11-18-2005, 12:53 PM   #4
Elbo
Elbo's Avatar
Send a message via MSN to Elbo
Re: JDM HID for Titan Review
The parts are all of very nice quality. The rubber weather boot on the back of the HID bulb is not really useable as far as I can tell. It's no big deal as the Titan doesn't have a weatherboot on their bulb either.
The kit came with some metal brackets that you could hard mount the Ballast box if you choose to. I skipped it and used some 3m Body Moulding tape ($4 from Autozone) and stuck it on to the shelf below the light assembly as show on Spank Monkey's instructions.
The JDM kit seems to be of higher quality than what I could see in Spank Monkey's kit he got from some other vendor.
The install took about 15 minutes per side. I didn't take any pictures because it would pretty much be redudant with Spanks pictures.
But I did post a lot of result pictures for you all to check out.
Here the first one is a test run.. HID one one side, with the Fog's running, good show of color difference.
Click image for larger version
Elbo is offline   Reply With Quote
