Old 11-18-2005, 03:53 PM   #15
Elbo
Elbo's Avatar
Send a message via MSN to Elbo
Re: Re-JUSTINTOXICATED-YOUR LEVELING KIT BLINDS THEM!
Originally Posted by PHOEBISIS
Justintoxicated,your stock lights are aimed too high because of your leveling kit.This is why you are being flashed;it isn't the brightness of the stock lights it is the aim.You tilted your nose(and the headlights) upward with the kit.Readjust your headlights-tilt them downward.
ELBO-great review and pictures.I have been eyeballing the JDMs since bestatchess mentioned that he installed them.Guess I should just pull the trigger and spend the $280.Thanks.Charlie
PS Are they the ones you find on Ebay with JDM mentioned in the heading?Do you have the sellers web address or Ebay name?Thanks!
http://stores.ebay.com/IMPORT-JDM-8000K-TRADING-INC
and seller name is
jdm8000kinc
I think his leveling kit is causing a problem.. I have never been flashed once. I drove around a little bit last night with the HID's I don't see any reason I would be flashed, They put out a ton of light, true, but it is aimed down at the road, as the last picture on the garage door shows.
and here is is regular non ebay website
http://www.japanjdm.com/
Elbo is offline   Reply With Quote
