Re: Nissan Titan as a plow truck?
Western makes a " surbanite" plow for the truck. You will have to remove the front skid plate for the mount to get in there. the plow is 7ft 4 iches and is lightweight. NOT for comercial use. you will trash teh plow and the truck.
Titan max payload is 1576 lbs. (King Cab XE 4x4) its 1680ish for crew cab 4x4 which woudl make it a 3/4 ton truck.
Im looking into a Wertern plow for it only because with the $$$ for plowing out here i could buy a new Truck after 1 season and pay cash for it..
as far a warranty being void.. the dealer will tell you changing your washer fluid yourself will void your warranty. id look for it in writing by Nissan MFG not a dealer.
