Old 11-20-2005, 07:48 PM   #7 (permalink)
bestatchess
Re: is your Rear axle seal Leaking
The breather sticks up about an inch or so on top of the axle tube housing on the right side. I was wondering if it might appear completely dry around the breather (no venting) and if that might be a sign that the breather is plugged or otherwise not working correctly, and if that might pressurize the axle seal and cause the leaking.
The breather/check valve is labeled with a blue arrow in the first photo of CJ3FLYR's breather tube extension thread (linked above)
