Old 11-21-2005, 08:19 AM   #9 (permalink)
TitanWannaBe
TitanWannaBe's Avatar
Re: dealership says slip light + ABS is low brake fluid?
I previously mentioned this problem...but I am also getting the Diff Lock light in adition to the Slip/ABS. The Diff Lock light will come on fisrt then it will switch to the Slip/ABS, then back to Diff Lock and so on. They only start coming on after I have driven a while(like after the differential has heated up???) They will stay on even if I make stop and turn of the truck for a short while. They will only go away if I park the truck for an extended period of time and let it cool completely. Then of course the whole ritual will start over again the next day.
I will try topping off the brake fuild resivouir tonight...but it seem if it were brake fluid that the lights would come on immediatly after starting the truck and not seem to be subject the lenght of time/distance traveled?
04' Titan SE CC OR BT RF
Born 08/04
TitanWannaBe is offline   Reply With Quote
