Originally Posted by Austin
Very doubtful you have toe in on both rear tires - although you could definitely have toe in on one tire. As Helinut1970 hinted at, when your axle is not exactly perpendicular to the truck, you get toe in on one side and toe out on the other side. That's called the thrust angle.
Can you post pictures of your tire wear?
Do you have any recent alignment specs you can post?
I had the tires rotated so I dunno which tires were on the back ones. Yeah I think I have a paper in my glove box from when they checked my alignment with a bunch of numbers. I will post it tomorrow.
