Old 11-23-2005, 07:05 PM   #2 (permalink)
92TripleBlack
92TripleBlack's Avatar
Re: 33" Terra Grapplers on 18s *Stock Height*
Now that's some meat. You need to get a lift and flares.
They are taller and wider than mine, and mine rub. With that offset, they stick a full inch out further than mine. You will find dirt, mud, rocks, rain, snow, etc. hitting your doors continuously without flares. Looks mean.
Stock Tire - 265/70R18
Tire 1 - 325/60R18
Tire 2 - 305/55R20
Section Width: 10.43 in 265 mm
Section Width: 12.79 in 325 mm
Section Width: 12.00 in 305 mm
Rim Diameter: 18 in 457.2 mm
Rim Diameter: 20 in 508 mm
Rim Width Range: 7 - 9 in
Rim Width Range: 8.5 - 10 in
Rim Width Range: 9 - 10 in
Overall Diameter: 32.60 in 828.04 mm
Overall Diameter: 33.35 in 847.09 mm
Overall Diameter: 33.20 in 843.28 mm
Sidewall Height: 7.30 in 185.42 mm
Sidewall Height: 7.67 in 194.81 mm
Sidewall Height: 6.60 in 167.64 mm
Radius: 16.30 in 414.02 mm
Radius: 16.67 in 423.41 mm
Radius: 16.60 in 421.64 mm
Circumference: 102.4 in 2600.9 mm
Circumference: 104.7 in 2659.3 mm
Circumference: 104.3 in 2649.2 mm
Revs per Mile: 638.0
Revs per Mile: 623.6
Revs per Mile: 626.5
Actual Speed: 60 mph 100 km/h
Speedometer1: 58.6 mph 97.7 km/h
Speedometer1: 58.9 mph 98.1 km/h
Speedometer Difference: - Speedometer Difference: 2.309% too slow Speedometer Difference: 1.835% too slow
Diameter Difference: - Diameter Difference: 2.25% Diameter Difference: 1.81%
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
