Old 11-24-2005, 10:16 AM   #7 (permalink)
titanse05
Re: Important Dynamat Question
Originally Posted by ecbmxer
Its like the Raamat, no asphaltic base. Doesn't smell. I'm gonna try and just run the heat in the truck while I'm putting it in and maybe use a hairdryer or something. I'll take some pics.
Good luck with that......I don't think that it will properly adhere if once you get it on there, the panel drops in temp again. Every quality deadener that I have used, most recently eDead SE, the instruction state a recommended min/max temps and 30 is well below the recommendations. If I were you I would wait and do it right in the spring. I have a couple projects that are on hold till spring.....
titanse05 is offline   Reply With Quote
