There is a thread about an attempted TruTrac install (Torsen style LSD diff carrier replacement). The splines weren't cut correctly on the part and he is waiting for a new one.
There is no factory LSD. If you don't get the e-locker, you get an open differential with ABLS where in the event wheel spin is detected, the brake caliper clamps the rotor on the spinning wheel.
Austin modified his e-locker to work in 2WD, 4x4 Hi, and 4x4Lo. The spider gears failed and he just got a new diff w/ e-locker under warranty.
TracTech, makes several products for other vehicles, including an Electrac which operates as a Torsen style LSD when unlocked and as a full locker when locked. The actuator sticks out from the diff cover and might get knocked off on rocky trails, but otherwise it might be the perfect arrangement if they decide to make one for the Titan.
http://www.titantalk.com/forums/tita...nals-pics.html
TruTrac locker for the Titan?
