Old 11-27-2005, 12:11 AM   #20 (permalink)
Deepwater
Deepwater's Avatar
Re: Titan Frame problem
Originally Posted by sxviper
well i don't think some of you understand what it is. if you are at the back of the truck looking at the back window, the bed is not level with the cab, i took measurments on the frame and springs and the right side is higher than the left side, in back by about an inch and in the front by about an 1/8 of an inch, that tells me that something in the back of the truck is wrong. by the way the body is also off right to left, front too back. the rear wheelwells are off by about 1.25 of an inch. both rear spring have been replaced by the dearler and that didn't fix it. they want to try and shim the bed and adjust the bumper to make it look level, but thats not fixing the problem.
I have noticed the same thing on my truck.
Thanks for your info and how did you get this problem solved?
Deep.
Deepwater is offline   Reply With Quote
