Re: How do i pull a stuck vehicle?
Wrap the recovery strap, or as we call them in the south-the snatch strap around the back axle close to the rear suspension. Have the stuck vehicle try to reverse (lightly) as you pull them backwards. Pull as straight as you can. Not at an angle if possible. Be gentle! Your Titan has a butt load of torque and can pull a small car to shreads if not careful. Patience is the key. If you can't get them out easily, get them to a safe, warm place and come back in daylight with shovels.
