The best way I've found to detect slow leaks is with a water hose. Jack that wheel up and run water over the tread area as you rotate it. Any air escaping will make bubbles. You should also check around the beads in the same manner to make sure the tire hasn't lost any of its seal to the rim.
And don't forget to check the valve core.
