Re: ELBO's LED MOODLIGHT!
Step 6.
Yes I'm sure you know what to do. Plug the little light back into the slot!
But before you mount the overhead console back, you will need to check and make sure that the LED Bulb works. Attach just the Overhead harness cable, and turn your headlights on.
LED's work with the polarity going in one direction, so if the bulb is plugged in the wrong direction, it won't work. So it if doesn't light up, just carefully turn it a quarter turn with the screw driver, remove it and rotate it 180, reinsert and try it with the polarity reversed. It should light up if you have the right voltage and direction on the LED..
Step 7.
Once you have confirmed that the LED works, put the console back to the ceiling, and reapply your screws. GO Carefully with the screws, just get them so ever gently snug, if you tighten them, your console plastic will CRACK!
STEP 8.. BE SURE TO LOOK BELOW FOR MY CONCLUSION! AS there is a bit more to the story!
