Re: 2 questions before I pull the trigger
Originally Posted by KTMNealio
It depends on the wheel mostly. I have my 33x12.5x17 Mud Terrains on a 17x10 with 0 offset. There still is at least an inch between the tire and the rear of the fender will. All I have is the PRG Kit. I had them mount up the tires I was interested in and put them on the vehicle to make sure they will clear. I suggest you do the same.
- Nealio
I have the stock 17" wheels. That's a good idea, I'll have them mount them up to check clearance first. Thanks.
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
"Straighten that tie, son."
