Old 12-16-2005, 08:32 PM   #17 (permalink)
Mike H.
Mike H.'s Avatar
Re: Here's # of Rear Diff Failures Reported
Hey gang, for the 2004's, one complaint is currently listed under "power train:axle assembly" but it is actually described as a differential failure. There are eight under "power train:driveline:differential assembly". Try to make sure they all go under the right classification (differential).
Edit:
Similar with the 2005's. There are two under "axle assembly" that should have been put with the other 4 complaints under "differential assembly".
Mod links (clickable):
