Old 12-20-2005, 05:58 PM   #10 (permalink)
CJ3FLYR
CJ3FLYR's Avatar
Re: Double solution VS Axle-wrap
Originally Posted by gr8titan
Additional photos on the placement of the "helper spring" for use vs axle wrap. Note the location in reference to the "rubber stop" of the overload spring.
Gr8Titan,
I did the helper spring in the way you did quite a while ago. It's been great. Did you happen to drive the truck part way through the job (just front or rear add-ons)? I am contemplating doing your 'in front of the axle' mod.
How did you get the helper springs in behind the axle. I had a b**ch of a time on my 05 4x4 OR. Squeezing that thing under the rubber roller... OMG!
Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
CJ3FLYR is offline   Reply With Quote
