Old 12-21-2005, 05:05 PM   #14 (permalink)
CJ3FLYR
CJ3FLYR's Avatar
Re: Double solution VS Axle-wrap
Originally Posted by gr8titan
Using an 8mm "hex" wrench, I removed the "rubber roller" first. Then installed/secured the helper spring as pictured above. Thereafter, I used a "C-clamp" to compress the helper spring for effortless re-installation of the "rubber roller". Remove the "C-clamp" after the roller is in place.....and...Presto!!!
Yes I drove the truck with the installation in different ways. One (first) was the "JT" method alone which works fine. But when I saw this "red spring" that is specifically designed for axle wrap, I replaced the "JT" spring. The "red spring" in itself works better than the "JT" method. Studying how the "axle wrap" evolves, I thought of reinforcing the rear half of the leaf spring utilizing the "JT" spring but installed in a non-conventional way. Thus the helper spring will prevent that rear half from bending downwards during hard acceleration. Lo and behold......much...much...much improved traction!!!! with almost negligible axle wrap.
Doh! I squeezed, wrestled and used a strap to winch the frame towards the axle. I agree about the rear spring helping considerably, the roller contacts the helper spring and really resists allowing the axle to twist. I didn't find the front ones on ebay. What did you type in the search? Thanks
Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
CJ3FLYR is offline   Reply With Quote
