Old 12-25-2005, 07:25 PM   #2 (permalink)
TitanTech659
TitanTech659's Avatar
Re: '06 Armada mirrors work on Titan?
There is a switch in the Armada that run the power folding mirrors. The connectors are different as well. There also will be wiring issues cause of the turn signal function and motors in the mirrors. BCM would probably have to be replaced. I'm sure it can be done but it will cost an arm and a leg. Then you have to find some sucker to do it. Good luck!!
TitanTech659 is offline   Reply With Quote
