Originally Posted by dss90c
I've searched the forums, and got a great deal of information to help me to install my DEI 561T. However, I have have 2 questions that I couldn't resolve through my research. I was hoping that some of you who installed the 561T could answer them.
1. Is anybody using the parking light output for verification? If so, how did you wire it into the vehicle? I know where to find the wire, but I am confused as to whether or not to use a relay for this.
2. I was planning to use the lock feature to trigger the remote start (I was going to use 3 pulses). I just want to clarify that I can pick this up at the lock/unlock switch at the driver's door panel. I confused myself as to whether this was for the trigger on the 561T or for the lock/unlock on a remote starter with alarm.
Thanks in advance for all the help. I am trying to do as much work up front so I can minimize the install frustrations to under a case of beer!
ok even though Ive posted already
...the PURPLE and GREEN wire are found inside the CAB at the BCM...those are the unlock and lock and where u can get pulses to turn on. I have mine in 3 clicks also...
for the park light output...man its been a while so someone can chime in but I think its a white and black wire u can find coming out of a plug in the lower dash....I believe...like I say its been a while and Ive been sick (broke out in hives last night...sucks) so Ill try to post more info if I can later...
good luck and maybe someone else can also chime in
