Originally Posted by dss90c
I've got my DEI 561T all hooked up and working, except for the activation trigger. If I touch the wire to the frame twice, the remote start activates and starts the truck. This works perfectly. The issue I have now is that when I tried to connect to the BCM using the violet wire at pin 65, it is constantly triggering the remote start. It will start the truck, but then shut it off quickly. All this is happening while I haven't pressed a button on the remote! I know I am missing something real simple here. Can anybody please point me in the right direction?
Is your DEI set up to lock the doors after starting, and is the same trigger wire used to shut down the engine? If so, here's what may be happening:
1. User pulses door locks
2. DEI sees pulse via activation trigger
3. DEI starts truck
4. DEI pulses door lock
5. DEI sees door lock pulse via same trigger and shuts off engine.
