Re: Not another remote start thread....
The wires from the bcm are the wires that go directly to the door lock actuators. I think they are actually power feeds to the actuators and not ground triggers. I think you need to go into the door and tap the blue wire for the door lock signal. Did you program it for 3 pulses? It is set at 1 pulse for default so as soon as you touch the wire at the bcm if it is at ground you get a start signal.
Here is the wiring diagram http://www.titantalk.com/forums/427255-post85.html
I stand corrected. The pulse you are looking for is a +12v pulse and not a ground pulse. See the follow on posts in this thread for the right answer. I'll leave this post here for the wiring diagram, it may help someone in the future.
Silver 4x4 SE CC, Born 3/04
Graphite Titanium
Off Road/No Locker, BIG TOW/VDC
Step Rails, Truxedo,
Gibson Cat Back, AEM Brute Force CAI
Hood Protector, Tinted Windows
My other car is a diesel
(02 VW Jetta TDI, 49 MPG)
Rockwood 2306 Travel Trailer
Equalizer Hitch, Prodigy Controller
