Re: Not another remote start thread....
Originally Posted by cttitan
The wires from the bcm are the wires that go directly to the door lock actuators. I think they are actually power feeds to the actuators and not ground triggers. I think you need to go into the door and tap the blue wire for the door lock signal. Did you program it for 3 pulses? It is set at 1 pulse for default so as soon as you touch the wire at the bcm if it is at ground you get a start signal.
Here is the wiring diagram http://www.titantalk.com/forums/427255-post85.html
I think you may be on to something. Guess that's why most have said to go into the door to set the door lock wiring. Thanks
After a year of too many other things to do I may actually install my Crime Stopper autostart/alarm system.
Nolan
2004 4x2 CC LE
Black Low Profile Bed tool box, Homemade bed cover, Delphi XM Roady2, Airbox mod w/Fram Air Hog filter, Banks Monster Exhaust installed, Mobile 1 Oil and filter, 85-145 Royal Purple Synthetic Diff fluid, Garmin Zumo 550 GPS, Blaupunkt ME3 TV/DVD player wired into factory dvd wiring Like llajumpvid did his except using two 7" monitors for front and back coverage.
