Old 01-21-2006, 09:41 AM   #2 (permalink)
helomech
helomech's Avatar
Re: biggest tires w/ leveling kit
Originally Posted by baker2406
Will 35/12.50r18 mud grapplers fit on my truck with just a front leveling kit? I plan on getting a 6" pro comp lift later but will this work? I noticed today that the stock 265/70r18's are 32's, so.....
I got this off or gregs website. Hope this helps.
Q: How big a tire can I put on my Titan if I install the PRG leveling kit?
GREG SAYS: Well, you can fit 33" tires even without a leveling kit. With installation of the PRG kit, most 35" tires mounted on a stock or factory wheel will clear without rubbing or with only very minor rubbing (however if you have the factory mudflaps you'll most likely need to remove them). What determines if you'll have rubbing is the wheel offset. Contrary to popular belief, the farther the tire sticks out the more chance you'll have of rubbing. This is because when you turn the tire swings in an arc. Rubbing occurs when the rear of the tire hits the inner fender liner. The more positive offset you have the bigger the arc the tire swings and the more likely it is to rub. Your best bet is to work with your tire and rim dealer to get a combination that fits properly.
helomech is online now   Reply With Quote
