Old 01-26-2006, 12:21 PM   #5 (permalink)
A2titan
A2titan's Avatar
Re: REAR END Wobble/Shake
I and others had posted about this some time ago. To lazy to look it up right now. Worked hard with my service manager to figure this out, did the same route, and also complained to the 800 number a number of times. What I found out in all this is it's due to engine lugging due to shift point of 5th and converter lockup being set so low in an effort to gain EPA mileage ratings. You can see this if you can get the lugging vibration around 45-46, then drop it into fourth. Vibration is Bye-Bye. A simple programing change would fix, but claimed EPA mileage would be affected and have to be changed on the window sticker and other press material.
05 Smoke SE CC Big Tow 4X4, Mods: PRG 2" front-PRG 1.5" rear,PRG rear Bilsteins, Banks Exhaust, Front Air Dam, Power Tailgate lock, Fram Air Hog, Prodigy brake controller, Extang Trifecta bed cover. Bed Fade TSB performed by Rhino!
A2titan is offline   Reply With Quote
