Re: Adding Steering Wheel Audio Controls
Step 8 Reinstalling Steering Wheel
- This is a little bit tricky, but simple process.
- Feed the orange and red wire clips back through. On opposite sides as shown.
- As you start to get the steering wheel in place. Remove your tape, again utmost care to not let that thing spin too much or fall off.
- As the wheel goes on. If you look at the steering wheel from the top you will see that the White Rubber Foot on the Spool, will fit into a recepticle on the back of the wheel. this is shown in one of the pictures below.
- Make sure you get the steering wheel aligned back on the shaft as you remembered it. And make sure it seats all the way down. You can tell that it is seated all the way down by comparing my pictures to your situation. When it is all the way in. You will see metal flush with both the shaft base and the grooves grabbing it from the steering wheel. I don't know how to phrase that better. But it should be flush. I had to realign it a couple of times to get it to seat fully.
- Once it is seated fully, check again your alignment.
- Now you can put the center bolt 19mm bolt back on. You may have to lock the wheel up to get it tight. Don't go mad crazy on the torque.
