Old 02-08-2006, 06:50 PM   #10 (permalink)
37L1
37L1's Avatar
Re: Rear Window Leak
Originally Posted by Marc
So it is going to be day 3 tomorrow that they have had it...does that seem excessive to fix a rear window leak?
My recent experience is, no, it isn't excessive.
They tried to fix mine via the TSB for the 04 slider. Fix didn't work. Had to replace entire window plus do the TSB on the new window per Nissan. It takes at least 24 hours or more for the sealant to cure before they can water test it to make sure there are no more leaks. If there are still leaks, more sealant, another 24 hours for cure and then water test again.
And that's if they get on it immediately after you bring it in and my experience tells me that doesn't happen all that often if the service department is real busy. Let's not even talk about parts availability either.
I would call them and not wait for them to call you to tell you it's ready.
2004 Titan Smoke LE CC
Born 11/18/03
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
All that is necessary for the triumph of evil is that good men do nothing.
Edmund Burke
