Re: front door panel removal
Unless they changed something for 2006, you remove 5 screws and then pull at the periphery to disengage the clips.
One screw under obvious little square tab.
One screw under small piece near little square tab.
Two screws under long thin trim piece on door pull handle (not door latch handle). Pry little thin trim piece out with something that won't mar plastic (e.g. butter knife).
Pull arm rest up & off (held by clips) & remove one more screw.
Pinch out courtesy light at bottom of door (if so equipped) and disconnect electrical connector.
Do not drop door panel after pulling off. It must be supported while releasing lock & latch cables located on inner side of door panel,otherwise you run the risk of breaking plastic detents.
Might want to buy a few extra of the orange clips as they tend to break. A panel fork tool may come in handy and can be bought at local auto parts store.
