Thread: Front End Noise
Old 02-17-2006, 05:35 AM   #8 (permalink)
PrerunnerGreg
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Re: Front End Noise
On the CST kit you use a modified stock swaybar endlink, its much less bulky than the rancho parts, it coulnt hit the bolt. also, that bolt should bearly clear the shock tabs, any chance they used the lower ball joint bolt for the shock bolt as its a bit longer. And I dont thenk there are any stop caps on this set-up. The cst fabricatied spindle will rub on the bracket for the sway bar mount, metal to meatal with nothing between.
