Old 02-18-2006, 07:25 AM   #7 (permalink)
loufish
loufish's Avatar
Re: Newb Questions on lifting titan
Think about this...lift for the sake of lift is just bling-bling crap! The biggest tire the Titan should run is a 35", and all you need is enough lift to run them(4inchs). You should concentrate on ride quailty with better shocks and such.
PRG Performance Kit w/SAW's
Pro Comp heavy & loud 35" Extreme A/T tires on Pro Comp 1028 Wana-be Bead lock wheels
Born 9/2004
2002 Honda XR650R
