Old 02-24-2006, 10:30 AM   #9 (permalink)
Titan4x4Aggie
Titan4x4Aggie's Avatar
Re: Titan vs. F-150 Tug-O-War
Originally Posted by helomech
Who ever had the most traction. It doesn't matter how much power you have if you don't have enough traction you will lose. We have a tug at work with a 4 cylinder ford that will tow that 3/4 ton ford all over the place and our titans also.
BS.
The 3/4 ton weighs much more, resulting in a greater frictional force (coefficicent of friction * weight on each tire). As a result, the 3/4 will be able to put more power to the ground and pull the 4 cylinder all over the place.
Unless the 3/4 has like 0.1 coefficient of friction and the 4-cyl has 1 for uf.
My new gas saver!!!!!!
