Re: Hard Top Tonneau Cover... any good ones?
Just a note, I have the Undercover, and this probably applies to the Snug as well. Be sure to look closely at both sides and make sure it is lined up with the sides of the bed correctly. I put mine on real fast, and didn't pay attention, that it was every so slightly crooked. It ended up being to tight on one side and scratched the paint a bit where the lip of the plastic comes over the side. It's been corrected, and nothing that a little bit of rubbing compound won't fix. But just spend the extra 2 minutes to check it out when you install it. That you don't have anything rubbing.
