I hope one of the supporting vendor jumps in and starts a group buy they start shipping next week.
http://www.perma-cool.com/Catalog/Cat_page18-1.html
Cool-Pack Electric Fan Units
• Eliminates factory fan clutch, fan, and shroud.
• Increases horsepower and torque.
• High output, low amp electric fans.
• Adjustable thermal controller.
• Robust aluminum assembly.
• Durable black powder coated finish.
• Classic design enhances engine compartment.
• Simple hand tool installation.
• Pre-assembled and wired.
Features include dual high output electric fans controlled with a 160°F-210°F adjustable thermal switch mounted in an aluminum assembly with a black powder coated finish. A special cross flow isolator, a Perma-Cool® exclusive, maximizes fan efficiency. The Cool-Pack mounts solidly to the existing radiator core support (not the radiator) and uses the stock fan shroud mounting holes and fasteners. Requires no drilling, tapping or modifications.
Installing Cool-Pack couldn’t be easier! Simply remove the stock fan shroud and fan clutch/fan assembly. Next, install the pre-assembled and pre-wired Cool-Pack using the factory holes and hardware. Finally, connect three wires (power, ground and air conditioning clutch.) That's all there is to it!
Share the wealth of knowledge and go as fast as you can.
IRC Crew Chief "International Racers Club VK56"
TESTING: GTech/Pro RR, AutoTap, Auto Enginuity Enhanced, UpRev, Audio Spectrum Analyzer for Knock Sensors Monitoring, HP nx9420 Notebook PC T7700, Sprint Mobile Broadband
MODS: Designer of the famous PGM 90mm Throttle Body and the PGM Throttle Body Spacer.
Designer of the Throttle Body Intercooler system. Custom CAI, Custom Ram Air, Custom 160 degrees Thermostat, Custom MagnaFlow Exhaust, Custom B-Pipe NO Cats in line and NO Simulator, Custom UpRev Tune’s
Nismo Headers, Flex-a-Lite Electric Puller Fan #295, Jim Wolf Technologies Camshafts, Detroit TruTrac LSD, ActiveTuning Grounding.
None of Stillen's Junk!
http://oathkeepers.org/oath/2009/03/...will-not-obey/
