Re: alignment PRG
The problem is that nissan dropped the ball and designed a ton of "bump steer" into the titans. any time you raise or lower the front more than around 1/2" it will mess-up the toe adjustment (lifted spindles actaully have less than the stock ones, go figure). Just as you needed to adjust the toe when you raised it, it would be right back to where it was before you raised it. Its about a 5 minute adjustemnt and not hard to do. At the same time, if you just put the spacer back in, it should not need an alignment as it will be right back to where it was before (although your tires have worn funny and it may feel a bit different).
