Old 03-20-2006, 06:08 AM   #15 (permalink)
sonnytimes
sonnytimes's Avatar
Re: Nissan Titan-NHSTA REPORTED FAILURES-of powertrain:driveline:rear differential unit:
I posted mine a long time ago before we got together to post on in the "Driveline: Differential Unit" catagory. I went back to look up my number and found it under the "Axle Assemblty" catagory. I also put jboth of my failures under the same complaint. I called the 1-888 number and someone is to call me back to see what I need to do. I was scared to make a complaint under both catagories unless the said it was OK. When they call me back I will see what they have to say. Here is my complaint # 10143873.
And the daily beatings will continue until morale improves.
Or until you figure out how to use their system against them.
04 LE 4X4 OR
05 and 06 Rear ends....
05 Bed, front seats, AC parts, brakes, window reg., .....
sonnytimes is offline   Reply With Quote
